PSE.gPROMS.ProcessBuilder.v1.0.beta4.Win32
Process.Systems.Enterprise.gPROMS.v4.00
gPROMS.ModelBuilder.v3.20
Process Engineering ToolS (PETS) v5.02
HTRI Xchanger Suite v7.3.2
HTRI Xchanger Suite v6.0 SP3 Full-ISO
HTRI v7.3.2
VMG 10.0
Heat Transfer Consultant ACX v3.5 repack
Heat Transfer Consultant STX v3.5
Fundamentals of Heat Exchanger Design 0471321710
Heat Exchanger Design Handbook 0824797876
Fractionation Research Inc Device Rating Program v3.0.3.736 repack
FRI Device Rating Program v3.0
FRI Device Rating Program v2.3.3
FRI-Database
FRI-ICES v2001
FRI-ICES v2002
FRI-Pack Rating v3.0
FRI-Positon Papers 2001 pdf
FRI-Resourece-CD2001
FRI-Resourece-CD2002
FRI-Resourece-CD2003
FRI Device Rating Program v1.1.4
PALS2000 R5 v5.0.15
VESA R1 v1.0.93
Onda HTC-BPLATE v1.12.0
Onda HTC-SHELL v2.9.0
CERBERUS v11.5
CAESAR II 2023 v13.00.Win64
Intergraph PV Elite 2019 SP1 v21.00.01
Intergraph CADWorx (Plant, P&ID, Equipment, IP, SpecEditor) 2019 v19.0.0 Win32_64
Intergraph CADWorx (Plant, P&ID, Equipment, IP, SpecEditor) 2017.01-ISO
Intergraph CADWorx (Plant, P&ID, Equipment, IP, SpecEditor) 2017 v17.00-ISO
Intergraph CADWorx Plant.2017.SP1.Update.Only
Intergraph CADWorx Design Review 2017
Intergraph CADWorx Structure 2017
Hexagon PPM COADE TANK 2017 SP1 v9.00.01
Intergraph TANK 2014 SP1 v6.00.01-ISO
Coade CADWorx DataSheets v2008
Coade CADWorx Design Review 2010
Coade CADWorx Equipment v2010 for AutoCAD
Coade CADWorx IP v2008
Coade CADWorx P&ID Pro v2010 for AutoCAD
Coade CADWorx Plant Pro v2012 for AutoCAD
Coade CADWorx Steel Pro v2008
Coade CADWorkx DataSheets Build Feb 2006
Coade CADWorx Pipe 3.1
Coade Tank v2012 Win32_64
epipingdesign.ASME.B31.1.Power.Piping.Calculator.v2016.full
epipingdesign.ASME.B31.3.Process.Piping.Calculator.v2016.full
epipingdesign.EN.13480-3.Pressure.Piping.Calculator.2017.full
Paul Lutus TankCalc v6.9
PLANT-4D v7.7.03 SP1-ISO
Visual Vessel Design 2015 with Update 1 v15.1
Coade CADWorx 2013
WeBBusterZ.Shell&THEx.v3.1.0.0.PPEDB.v3.6.1
Shell and Tube Heat Exchange Design v3.1.0.0
Physical Properties Estimation Database v3.6.1
TechnoSoft AMETank v15.2.16
TechnoSoft AMETank v10.3 Win32
TechnoSoft AMETank v9.7.9 Win32_64
Hydraulic UnderBalanced Simulator(HUBS) R3.2.1
KYPipe Pipe 2022 v11.002
Schlumberger (SPT Group) Drillbench 2022.2.1
Drillbench Cemcalc v3.9
MEPO v3.2.4
Calsep.PVTsim.Nova.v5.4.44.Win64
PVTsim Nova 1.3.104 Win32
PVTsim v20.0-ISO
Paulin Research Group(PRG) 2021
Paulin Research Group 2019
Paulin Research Group(PRG) 2018
PRG PAULIN v2011
Nozzle/Pro 8.5
FE/Pipe 6.5
BOS Fluids 4.6
PCLGold v.4.0.2
Proware.Metsim.v2017.09
Equity Engineering Group PlantManager v3.0.1.18956
Schlumberger Petrel 2018.2 Win64
Petrel 2017.4 v17.4.0.9548 Win64-ISO
Petrel v2016.3 Win64
Petrel.2015.5.Win64-ISO
Petrel 2015 Plugins
Petrel Guru 2015 Content
Petrel 2014.2 With plugins Win64
Petrel v2011.1.0 Win64
Petrel.v2010.2.2.Win32-ISO
Petrel.Reservoir.Engineering.3.Day.Course
Petrel 2010.2.2 Full Manual
Blueback Bridge v5.0.4 for Petrel v2010.2.2 Win64
Schlumberger (ex Waterloo Hydrogeologic) Visual HELP v2.2.0.2
Schlumberger.AquaChem.12.build.20.23.0613.1
Schlumberger AquiferTest Pro v12.0.0 Win64
Schlumberger AquiferTest 10.0.0
Schlumberger AquiferTest Pro 2016.1
Schlumberger CemCade v4.4
Schlumberger Drilling Office v2008.1
Schlumberger ECLIPSE Simulation v2022.2 Win64
Schlumberger.Eclipse 2012.1 Win32_64-ISO
Schlumberger.Eclipse v2007
Schlumberger Eclipse v2001a-ISO
Schlumberger GeoFrame 2012 Linux-ISO
Schlumberger GeoFrame 2012 SP6 Update Only Linu-ISO
Schlumberger GeoFrame v4.5 Linux-ISO
Schlumberger GeoFrame 2012 video library
Schlumberger.Hydro.GeoAnalyst.11.build.20.22.0907.1
Schlumberger.Hydro.GeoAnalyst.Plus.v9.0
lioyd's register Interactive Correlation(I.C) 2016 v4.1.0 Win64
Schlumberger Integrated Asset Modeler (IAM) 2018.1 Win64
Schlumberger.Interactive.Petrophysics(IP).v4.5.5
Schlumberger.Interactive.Petrophysics.v4.0.2012.53.Update.Only
Schlumberger Malcom 2022.1.1 Win64
Schlumberger.OilField.Manager.2019.1
Schlumberger Sensia OFM 2022.1 build 922 Win32_64
Schlumberger OilField Manager(OFM) 2014.1-ISO
Schlumberger OLGA 2022.1.0.35696 Win64
Schlumberger.OLGA.2021.2.Win64
Olga Advance Blowout Control(ABC) v2.20
OLGA 2000 Exercises
Schlumberger Omega 2700 Linux
Schlumberger.SPAN.Rock.v9.1.5
Schlumberger Perforating Analysis (SPAN) v8.0
Schlumberger PIPESIM 2022.2.809 Win64
Schlumberger.PIPESIM.v2013.1.2
Schlumberger TDAS v6.1.6
Schlumberger Techlog 2018.2 Win64
Schlumberger Techlog 2015.3 Win64
Schlumberger Techlog 2011.2.2 Win32_64-ISO
Schlumberger Visage 2009.1 Windows
Schlumberger Waterloo Hydrogeologic Visual MODFLOW Flex v9.0 Build 9.0.412.45223 Win64
Schlumberger MODFLOW Flex 2012.12 Win32
Schlumberger MODFLOW Flex 2012.1 v1.0.52.0 Win32_64
Schlumberger.PetroMod.2019.1.Win64
Schlumberger.PetroMod.v2012.1
Schlumberger PetroMod v2012.2 Win64
Schlumberger.PetroMod.2011.1.Manual
Schlumberger VISTA 2021.000.14177 Win64
Schlumberger Waterloo Hydro GeoAnalyst 11.0 and AguanChem 11.0 Win64
Schlumberger Waterloo Hydrogeologic Visual MODFLOW Flex v6.1 Win64
Schlumberger Waterloo Hydrogeologic Visual MODFLOW Flex v7.0 Win64
Schlumberger.Visual.MODFLOW.Flex.2015.1.Win32_64
Schlumberger.Visual.MODFLOW.Pro.Classic.Interface.v4.6.0.166
Senergy.Interactive.Petrophysics.v4.2.2013.275
Merak Peep 2007.1-ISO
Oilfield Data Manager v3.6.09
OpenSpirit v3.22 Win32
OpenSpirit v3.2.2 Linux
Roxar EnABLE v2.3 Linux
Roxar RMS 2022 v13.1 Win64
Roxar.Irap.RMS.v2011.Win32-ISO
Roxar.Irap.RMS.v2013.rev.173741.Win64-ISO
WELLTEST v6.2
Eware.ETank2000.v1.9.0.15
ESSS Kraken v2.16 SP4 Win32
StrataGen Fracpro 2019 v10.10.13.0
FracproPT.2011.v10.5.21.0
AVEVA Pro/II Simulation 2021 Win64
AVEVA SimSci PROII Simulation 2020 Win64
Schneider Electric (ex. Invensys) SimSci PRO/II v10.2 Win64
Schneider Electric (ex. Invensys) SimSci PRO II v10.0
Schneider-Electric ClearSCADA 2013 R1.2 Win32_64
Invensys SimSci-Esscor PRO/II v9.4-ISO
KG-TOWER v5.0 & Utility for SIMSCI.PROII.v9.0
Koch.Glitsch.KG.TOWER.v5.01.013
AVEVA (ex. Invensys, SimSci) Inplant.Fluid.Flow.Design.2022.Build.12.10.2022
SimSci.Esscor.INPLANT.v4.3.0
AVEVA (ex. Invensys, SimSci) PIPEPHASE Pipeline Network Design 2022.Build.12.10.2022
AVEVA (ex. Invensys, SimSci) PIPEPHASE Pipeline Network Design 2021 Win32_64
SimSci-Esscor.PipePhase.v9.6-ISO
SimSci.Esscor.PRO.II.v9.2
SimSci.DataCon.v3.13
AVEVA.Process.Optimization.2022.Build.11.10.2022
AVEVA.Process.Simulation.2023.Build.10.10.2022
AVEVA Process Simulation 2022 v6.0.0.0645
AVEVA.Process.Simulation.Hextran.2021.Win64
SimSci.Esscor.HEXTRAN.v9.2
SimSci.Process.Engineering.Suite(PES).2002-ISO
Simulation.Sciences.Process.Engineering.Suite.2000-ISO
Invensys.Pro.II.v9.1-ISO
AVEVA Dynamic Simulation(DYNSIM) 2022.Build.28.04.2022.Win64
AVEVA.DYNSIM.2021.Win64
Invensys.SimSci.Esscor.DYNSIM.v5.3.2
Invensys Simsci Romeo v4.3.1
AVEVA Simulation For Foxboro Control 2021
AVEVA.Visual.Flare.Safety.Relief.Design.2022.Build.02.11.2022
AVEVA.VisualFlare.2021.Win64
Kongsberg LedaFlow Engineering v2.6.260.024 including KBC Multiflash v6.2.61 Win64
Kongsberg.LedaFlow.Engineering.v1.7.248.921
Metso Minerals Bruno Simulation v4.1.0.8
OLI.System.2010
OLI ScaleChem v4.0.3
Orange Technologies CADPIPE Gen2 v6.2
Orange.CADPIPE.Gen2.v3.1.for.AutoCAD.2014-2015.Win64
Orange.Technologies.Cadpipe.Suite.v12.6
CadPipe HVAC v5.4
CadPipe v5.4
AutoPlant 3D v2.01
AutoPIPE.v6.20.WinAll
Ansys Chemkin Pro 17.0 Release 15151 Win64_Linux64
Reaction.Design.Chemkin.Pro.15131.Win64
Reaction.Design.Chemkin.Pro.v15083.WinNT_2K
Reaction.Design.Chemkin.Pro.v15083.Linux
Reaction.Design.Chemkin.Pro.v15083.Linux64
Reaction Design Chemkin v4.0
ChemDraw.Professional.v15.0.0
ChemEng Software Design ChemMaths 17.7
ChemEng Software Design DataPro v10.2
ChemEng Software Design ProsimgraphsPro v10.2
ChemEng Software Design ChemMaths v17.0
ChemEng Software Design ChemMaths v16.0
ChemOffice.BioAssay.Ultra.2008.v11
ChemOffice.Inventory.Ultra.2008.v11
ChemProject 6.3.0
PerkinElmer ChemOffice Suite 22.2.0.3300 Win32_64
PerkinElmer ChemOffice Suite 2020 v20.0.0.41
ChemOffice.Professional.15.Ultra.Suite.15.0.0.106
ChemOffice Professional v17.0.0
ChemOffice.Ultra.v12.0
Cambridge.Structural.Database(CSD).2017
CambridgeSoft ChemBioOffice Ultra 13.0 Suite
ChemACX.Ultra.v10.0.DVD-ISO
Hydromantis Toxchem v4.3.6.3
Hydromantis Watpro v4.0
DOW.Chemical.Science.CADIX.Ion.Exchange.Design.2022.v6.10
Applied Flow Technology Arrow 2023 v10.0.1100 build 2023.10.02
Applied.Flow.Technology.ChemPak.Add-in.for.Excel.v2010.01.28
Applied.Flow.Technology.ChemPak.Viewer.v2.0.2011.02.02
Applied.Flow.Technology.Engineering.Utility.Suite.v2.0.2010.01.28
Applied Flow Technology Fathom v13.0.1100.0 build 2023.09.14
Applied Flow Technology (AFT) Fathom 12.0.1108.0
Applied Flow Technology (AFT) ImpFullz v9.0.1108 Build 2022.11.11
Applied Flow Technology Impulse v9.0.1102 build 2022.05.11
