Total : 5438247
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/affiche_compteur.php on line 48: fopen(../stats/2024/03.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/affiche_compteur.php on line 68: fopen(../stats/2024/semaine/13.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/affiche_compteur.php on line 90: fopen(../stats/2024/jour/88.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 8: fopen(stats/2024/03.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 28: fopen(stats/2024/semaine/13.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 37: fopen(stats/2024/semaine/13.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 54: fopen(stats/2024/jour/88.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 62: fopen(stats/2024/jour/88.txt): failed to open stream: No such file or directory
Nocturne Vendredi soir
Messagepar guigui » 06 Sep 2017, 09:47
Salut à tous,
Si le temps le permet, je sors en nocturne vendredi soir avec des potes.
Départ vers 19h30-20h pour un retour vers 22h - 22h30.
On va tourner du côté de Busy, Vorges, Boussières, Abbans, Montferrand.
Qui vient ?
Re: Nocturne Vendredi soir
Messagepar LaurentD » 06 Sep 2017, 18:55
Pas possible pour ma part.
Bonne balade ;)
LaurentD
Messagepar mica » 06 Sep 2017, 23:58
slt ca dependra de la meteo. Le rdv est ou?
mica
Messagepar guigui » 07 Sep 2017, 20:27
Depart vers 19h30 20h à busy ou avanne
Je reconfirme dans la journée demain
