Total : 152494322
NCH DreamPlan Plus 7.50
Messagepar filedown00 » 14 Déc 2023, 21:26
HONEYWELL UniSim Design Suite R492 (Build 24214 Release)
HONEYWELL UniSim Design Suite R461.1
HONEYWELL.UniSim.Design.Suite.R460.1
Honeywell.UniSim.Heat.Exchangers.R460.1
HONEYWELL UniSim Design Suite R451 Build 20113
Honeywell.UniSim.Flare.R390.1-ISO
HONEYWELL.UniSim.Design.Suite.R390.1
Unisim Design R370.1-ISO
Honeywell.Predict.v6.1.19.465
Honeywell.PredictPipe.v3.0
Honeywell.RiskIT.v1.0
Honeywell.Socrates.v10.0.17.0
Honeywell.Socrates.v8.0.repack
Honeywell Strategy-B v3.0.0.2
Honeywell.Strategy-A.v3.1
Schlumberger (ex. Softbits) Flaresim 2023.2
Flaresim User Manual
Flaretot.v1.4.2.0
Flaretot.Pro.v1.3.9.0
Flaretot.v1.2.1.0
PSE.gPROMS.ModelBuilder.v4.20.Win32
PSE.gPROMS.ProcessBuilder.v1.0.beta4.Win32
Process.Systems.Enterprise.gPROMS.v4.00
gPROMS.ModelBuilder.v3.20
Process Engineering ToolS (PETS) v5.02
HTRI Xchanger Suite v7.3.2
HTRI Xchanger Suite v6.0 SP3 Full-ISO
HTRI v7.3.2
VMG 10.0
Heat Transfer Consultant ACX v3.5 repack
Heat Transfer Consultant STX v3.5
Fundamentals of Heat Exchanger Design 0471321710
Heat Exchanger Design Handbook 0824797876
Fractionation Research Inc Device Rating Program v3.0.3.736 repack
FRI Device Rating Program v3.0
FRI Device Rating Program v2.3.3
FRI-Database
FRI-ICES v2001
FRI-ICES v2002
FRI-Pack Rating v3.0
FRI-Positon Papers 2001 pdf
FRI-Resourece-CD2001
FRI-Resourece-CD2002
FRI-Resourece-CD2003
FRI Device Rating Program v1.1.4
PALS2000 R5 v5.0.15
VESA R1 v1.0.93
Onda HTC-BPLATE v1.12.0
Onda HTC-SHELL v2.9.0
CERBERUS v11.5
CAESAR II 2023 v13.00.Win64
Intergraph PV Elite 2019 SP1 v21.00.01
Intergraph CADWorx (Plant, P&ID, Equipment, IP, SpecEditor) 2019 v19.0.0 Win32_64
Intergraph CADWorx (Plant, P&ID, Equipment, IP, SpecEditor) 2017.01-ISO
Intergraph CADWorx (Plant, P&ID, Equipment, IP, SpecEditor) 2017 v17.00-ISO
Intergraph CADWorx Plant.2017.SP1.Update.Only
Intergraph CADWorx Design Review 2017
Intergraph CADWorx Structure 2017
Hexagon PPM COADE TANK 2017 SP1 v9.00.01
Intergraph TANK 2014 SP1 v6.00.01-ISO
Coade CADWorx DataSheets v2008
Coade CADWorx Design Review 2010
Coade CADWorx Equipment v2010 for AutoCAD
Coade CADWorx IP v2008
Coade CADWorx P&ID Pro v2010 for AutoCAD
Coade CADWorx Plant Pro v2012 for AutoCAD
Coade CADWorx Steel Pro v2008
Coade CADWorkx DataSheets Build Feb 2006
Coade CADWorx Pipe 3.1
Coade Tank v2012 Win32_64
epipingdesign.ASME.B31.1.Power.Piping.Calculator.v2016.full
epipingdesign.ASME.B31.3.Process.Piping.Calculator.v2016.full
epipingdesign.EN.13480-3.Pressure.Piping.Calculator.2017.full
Paul Lutus TankCalc v6.9
PLANT-4D v7.7.03 SP1-ISO
Visual Vessel Design 2015 with Update 1 v15.1
Coade CADWorx 2013
WeBBusterZ.Shell&THEx.v3.1.0.0.PPEDB.v3.6.1
Shell and Tube Heat Exchange Design v3.1.0.0
Physical Properties Estimation Database v3.6.1
TechnoSoft AMETank v15.2.16
TechnoSoft AMETank v10.3 Win32
TechnoSoft AMETank v9.7.9 Win32_64
Hydraulic UnderBalanced Simulator(HUBS) R3.2.1
KYPipe Pipe 2022 v11.002
Schlumberger (SPT Group) Drillbench 2022.2.1
Drillbench Cemcalc v3.9
MEPO v3.2.4
Calsep.PVTsim.Nova.v5.4.44.Win64
PVTsim Nova 1.3.104 Win32
PVTsim v20.0-ISO
Paulin Research Group(PRG) 2021
Paulin Research Group 2019
Paulin Research Group(PRG) 2018
PRG PAULIN v2011
Nozzle/Pro 8.5
FE/Pipe 6.5
BOS Fluids 4.6
PCLGold v.4.0.2
Proware.Metsim.v2017.09
Equity Engineering Group PlantManager v3.0.1.18956
Schlumberger Petrel 2018.2 Win64
Petrel 2017.4 v17.4.0.9548 Win64-ISO
Petrel v2016.3 Win64
Petrel.2015.5.Win64-ISO
Petrel 2015 Plugins
Petrel Guru 2015 Content
Petrel 2014.2 With plugins Win64
Petrel v2011.1.0 Win64
Petrel.v2010.2.2.Win32-ISO
Petrel.Reservoir.Engineering.3.Day.Course
Petrel 2010.2.2 Full Manual
Blueback Bridge v5.0.4 for Petrel v2010.2.2 Win64
Schlumberger (ex Waterloo Hydrogeologic) Visual HELP v2.2.0.2
Schlumberger.AquaChem.12.build.20.23.0613.1
Schlumberger AquiferTest Pro v12.0.0 Win64
Schlumberger AquiferTest 10.0.0
Schlumberger AquiferTest Pro 2016.1
Schlumberger CemCade v4.4
Schlumberger Drilling Office v2008.1
Schlumberger ECLIPSE Simulation v2022.2 Win64
Schlumberger.Eclipse 2012.1 Win32_64-ISO
Schlumberger.Eclipse v2007
Schlumberger Eclipse v2001a-ISO
Schlumberger GeoFrame 2012 Linux-ISO
Schlumberger GeoFrame 2012 SP6 Update Only Linu-ISO
Schlumberger GeoFrame v4.5 Linux-ISO
Schlumberger GeoFrame 2012 video library
