[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/fonction.php on line 14: mysql_connect(): User o3450566 already has more than 'max_user_connections' active connections
Total : 5573966
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/affiche_compteur.php on line 48: fopen(../stats/2024/04.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/affiche_compteur.php on line 68: fopen(../stats/2024/semaine/17.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/affiche_compteur.php on line 90: fopen(../stats/2024/jour/118.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 8: fopen(stats/2024/04.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 28: fopen(stats/2024/semaine/17.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 37: fopen(stats/2024/semaine/17.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 54: fopen(stats/2024/jour/118.txt): failed to open stream: No such file or directory
[phpBB Debug] PHP Warning: in file /homepages/19/d290682188/htdocs/compteur/nb-visiteurs.php on line 62: fopen(stats/2024/jour/118.txt): failed to open stream: No such file or directory
Mercredi 5-09
Mercredi 5-09
Messagepar Clem » 04 Sep 2012, 14:06
Je vais rouler mercredi, départ 17h30-17h45 pour deux heures dans Chailluz, Dame-Blanche (peut-être 2 fois par deux côtés différents pour bouffer du dénivelé) !
Re: Mercredi 5-09
Messagepar Pascal » 04 Sep 2012, 17:20
Je pense pouvoir venir ce mercredi pour 17h45 au parking,
Ce soir je mets les lampes à charger et je viens avec .... après Métabief, ce sera Chailluz by night
Re: Mercredi 5-09
Messagepar guigui » 04 Sep 2012, 21:17
Je pourrai pas venir avec vous demain soir.
Re: Mercredi 5-09
Messagepar Clem » 05 Sep 2012, 09:59
OK pour moi. RDV à 17h45 au parking comme la dernière fois.
Tu peux m'appeler jusqu'à 16h15 après je serai en moto
Re: Mercredi 5-09
Messagepar Clem » 06 Sep 2012, 09:58
Une bonne petite sortie finie encore une fois en nocturne, on y prend goût !!!
38 km, 780 m de D+ au départ de chez moi. Un peu moins pour Pascal que j'ai retrouvé directement dans la forêt.
La Dame Blanche par la grande côte on a bifurqué juste avant l'antenne pour redescendre sur la route qui longe l'autoroute. Puis remontée de la Dame Blanche par le chemin de débardage. Descente par la crête technique puis par "le ruisseau" qui coupe le chemin blanc. Retour sur les grandes baraques, un petit tour autour des enclos animaliers et on fini en repartant sur la fontaine des acacias.
Re: Mercredi 5-09
Messagepar txurruka » 06 Sep 2012, 17:54
Wahou ! 2 grosses montées alors, bien joué.
Re: Mercredi 5-09
Messagepar Pascal » 06 Sep 2012, 19:45
Moqueur . :mrgreen: !
Re: Mercredi 5-09
Messagepar txurruka » 06 Sep 2012, 20:10
Non, juste je ne m'imagine pas arriver tout près de l'antenne sans même aller voir le panorama, et descendre direct, puis remonter (même par un autre chemin) au même endroit ^^ Faut de la motiv quoi.
